Topic: Found a small bug (or confusion) in CMS new "Login as" feature
Hi!
The icon shown for performing the "Login as" action is two arrows pointing in opposite directions. Such an icon is generally used to perform a swap or exchange action, not to login. It wasn't obvious this icon was intended as the button to perform the login. A more commonly used icon is an arrow pointing into a doorway or circle/rectangle. Examples:
https://www.google.com/search?q=login+a … mp;bih=966
Can an icon update take place to eliminate confusion moving forward please?
