NimBus Displaying routes based on the order of arrival
Topic: NimBus Displaying routes based on the order of arrival
right now If a nimbus locator user search for stop,routes are not displayed based on arrival time.It will be great if we sort the list based on arrival time(next bus arriving should be on the top of list)
Re: NimBus Displaying routes based on the order of arrival
Hi siju,
For now it works the following way. First of all routes are grouped by the type of transport (e.g. buses). Inside each group we filter the routes by route numbers. E.g. route 3, than route 7, then route 25 and so on.
Also at the moment we don't have ETA in the Locator. But we will consider this option, thank you for the request!
Dear partners, you are very welcome to share your views on the subject.
Viktoria Chabai
Product Manager, Wialon
Dear siju,
I'm happy to tell you that this feature has been implemented in our latest update!
Viktoria Chabai
Thanks a lot
