Fuel card
Topic: Fuel card
Hello,
Here i want to say something about the fuel card option in the wialon by which we can see real amount of fuel on the wialon if the customer fuel card
API connect with our wialon platform and also we can compare the fuel which is showing by the sensor and the exact value of fuel which one is coming
with the fuel station
Thanks & Merci
YOGESH VERMA
Fuel card
Re: Fuel card
Hello, yogesh verma
The problem with fuel card is in their diversifications: most companies have their formats, coverage, and politics. So we recommend doing custom development by your exact requirements on your side, as it's hardly possible to take into account even not all, but the most popular systems for all customers in Wialon.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Fuel card
Re: Fuel card
Thank you tata
Thanks & Merci
YOGESH VERMA
Fuel card
Re: Fuel card
Question.mostly of data we need from petrol cards are:
date
liters
price per liter
object
Question
this can be included as event.
Option I think...maybe it can be created as import archive integrating those fields?
As I know those petrol companies sends every month .xls file with this info.
Maybe it can be a kind of integration? if you think..at the end it is not so diferent as trackers integration but more simple...
What do you think about it?
In my country I saw those files from the 3 most important ones (that are working over ther world) and have same info...
thanks
thanks
Locating things
