Import failed
Topic: Import failed
I'm trying to migrate an account from my Wialon Test environment to the new Wialon Hosting environment.  The import is failing.  I have migrated the account Geofences and Units but the notifications are still failing.
Is there a trick to get notifications to import?  The units were removed from the old account and then the export of resource was done but it still gives a failure message trying to import with only the notifications selected.
Import failed
Re: Import failed
Hello,
Most likely, this issue is connected with difference in resources' creators' access to the units. Try to export/import the notification logged as top-user of the whole service.
If this hint won't help you, please, send us more information to the support@gurtam.com
@ Oleg Zharkovsky
Import failed
Re: Import failed
zark wrote:
Hello,
It was an issue with the unit id's.  I worked with support and was able to update and import.
