API Permission
(edited by tkabeary 11/10/2018 18:08:27)
Topic: API Permission
I'm trying to load messages via API.  I've gotten a tokens using both the flag 0x200 and 0x1000
After using this tokens to get my SID, I'm trying to load 24 hours of messages for a unit.
I've copied the example.
Here's my call:
https://hst-api.wialon.us/wialon/ajax.html?svc=messages/load_interval&params={"itemId":355922063939942,"timeFrom":1539181665,:"timeTo":1539268065,"flags":1,"flagsMask":65281,"loadCount":3}&sid=410ea6e2fe44c32f0a81eb0aaaa688d3
SIDs from tokens with the mask 0x1000 and 0x200 both return:
  "error": 7
What permissions do I need to load these messages?
Thanks
API Permission
Re: API Permission
Hello tkabeary.
Are you sure this item id is valid?
For view and check access you can show this link https://sdk.s-watcher.com/wiki/en/sidebar/ … s_billing:
Best regards
