Create a 2-parameter trigger alert
Topic: Create a 2-parameter trigger alert
Would you like to create an alert that triggers when the ignition is off and the motorcycle is moving?
Renato Salão - www.kademeucarro.com.br
Re: Create a 2-parameter trigger alert
You can use one of the following ways to get such a notification:
1) Use notification with type "Speed" with additional sensor value filter.
If you use this way, then you will have possibility to tune "Min duration of alarm state" only for speed parameter, because this and all the other notification parameters are applied only for main criteria -- speed.
2) You can create 2 unit groups (e.g. for units with ignition on and for other) and 3 notifications to do the following:
* 1st notification will move units from group "Ignition off" to "Ignition on" based on sensor value.
* 2nd notification will do it visa versa (from group "Ignition on" to "Ignition off").
* 3rd notification should control speed in group "Ignition off" and send email or SMS (depending on clients needs).
@ Oleg Zharkovsky
(edited by hhamedk 01/09/2018 07:55:11)
Renato, It's also possible to create a Movement sensor and the second one (let's call it X sensor). X sensor type should be custom digital sensor and parameter is ignition parameter and you should set Movement sensor as validator. Then use X sensor in notification.
