Wialon JS API - app authentication token
Topic: Wialon JS API - app authentication token
Dears,
I am  using this code to generate a token,
https://sdk.s-watcher.com/playground/demo/app_auth_token
how to generate a permanent token without duration period ?
Thank you for your support,
Mina Fouad
Re: Wialon JS API - app authentication token
Fot this you need put the param duration with 0
thank you
