Topic: Enhanced View/Edit Access Rights
Description of the issue
Currently access rights defined for an account or user apply to one or more features, but is not possible to restrict access to one section and not to another because both sections are linked together and managed by the same access right.
I would share with you an example of this situation:
Custom fields
https://docs.s-watcher.com/en/hosting/cms/units/fields
and
Profile
https://docs.s-watcher.com/en/hosting/cms/units/charact
are both controlled by
View custom fields — to view this tab, Manage custom fields — to edit this tab.
https://docs.s-watcher.com/en/hosting/cms/rights/standard
Thus, is not possible to grant access to profile tab but not to custom fields.
The proposed idea is
Implement access right for each tab separatly, thus adding for example the options:
-View Custom Fields
-View Profile
-Manage Custom Fields
-Manage Profile
Please note this is an example, the intended idea is that we can control each tab in every dialog and among any menus.
It would be even better if we can control this in a WYSIWYG enviroment, but this is for another version in the future
, but is ok if we can control this, at least in the old way.
End users:
This will apply to any one that wants to fine control the access permision of his users and mostly for his distributors.
Remarks:
Hope that other users and mostly distributors can support this idea, because it will allow to fully manage the entire platform according every need.
Best regards and happy coding
With love from Chile ![]()
System development and integration
Разработка системы и интеграция
www.techdev.cl
