Custom Report
Topic: Custom Report
Hello All,
Actually i'm looking for custom report that requesting by one of my customer and i don't  know how to do it
and i will send you the sample if you don't mind
Please some one tell me how to do this report or how to develop it
Custom Report
Re: Custom Report
You will have to use Wialon SDK.
You can generate report with API https://sdk.s-watcher.com/wiki/en/kit/remo … xec_report
If you do not have developers contact your sales manager to give you details of any 3rd party developer how can assist you.
Cheers
Nishad Hussain Kaippally
Custom Report
Re: Custom Report
Hi,
Tapping on this post. To generate report using API, do I need to create the report first in Wialon and then only use API to run the report and extract the result?
Custom Report
Re: Custom Report
I cant take the data of the header
how can I receive the data of the report
  • Custom Report
Custom Report
(edited by cerpas 19/09/2018 00:20:46)
Re: Custom Report
Hello.
To execute and get information to a report template normally you need folow the next steps.
1. report/execute_report.  https://sdk.s-watcher.com/wiki/en/sidebar/ … ec_report.
2. report/select_result_rows https://sdk.s-watcher.com/wiki/en/sidebar/ … esult_rows
3. report/cleanup_result https://sdk.s-watcher.com/wiki/en/sidebar/ … nup_result
You can show a good example on this url
https://sdk.s-watcher.com/wiki/en/local/re … /reports?s[]=report&s[]=select&s[]=result&s[]=rows
Best regards
