Utility to import fines to Wialon using APIs
Topic: Utility to import fines to Wialon using APIs
Hello ,
Was wondering if there is a utility developed by someone in the community that will help importing fines from an excel sheet (or some sort of flat-file) into Wialon by adding them as custom events ) marked as violations.
Appreciate your help on this.
Thanks,
Karim.
Re: Utility to import fines to Wialon using APIs
Hello
Can you show sample of such file?
Hello Shmi,
thanks for the reply, attached is a demo file I created for a couple fines.
Regards.
(edited by kaippally 04/06/2018 08:34:12)
Dear Karim
There is an import example in our Javascript playground.
Once the data is imported do a batch of register_custom_events
https://sdk.s-watcher.com/playground/demo/import_fillngs
Nishad Hussain Kaippally
