Export to WLP - Unit
Topic: Export to WLP - Unit
I'm trying to export to WLP by choosing following option
1. Export From as "Unit"
2. export option as "General properties"
and getting the following content in the WLP file.
{"general":{"hw":"Wialon IPS","n":"Unit Name","ph":"","ph2":"","psw":"","uid":"","uid2":""},"mu":0,"type":"avl_unit","version":"b4"}
Which API you are using to read hw vaue "Wialon IPS". I have tried to get that value using the below API, but no use.
{"svc":"core/search_item","params":{"id":*****,"flags":9007199254740991}}
Thanks
J Prabhu
Re: Export to WLP - Unit
Try this
{"svc":"core/search_item","params":{"id":****,"flags":257}}
Nishad Hussain Kaippally
In the result I'm getting hardware type ID as "96266", but I'm expecting string value ("Wialon IPS").
"hw":<long>,    /* hardware type */
Thanks
J Prabhu
prabhu.janakiraman, use this request https://sdk.s-watcher.com/wiki/en/sidebar/ … t_hw_types
to to get hw name by it's id.
