User settings flags Computation
Topic: User settings flags Computation
I'm using core/search_item API method to fetch following user setting for a user, its returning "fl", How to get values(true / false) for the following settings using the flag "fl"
    "fl":<uint>,    /* user settings flags */
    "hm":<text>    /* host mask */
Can create items:                    True / False
Can change password:        True / False
Can send SMS:                    True / False
Enabled:                                     True / False
Can change settings:               True / False
Thanks in advance
Thanks
J Prabhu
Re: User settings flags Computation
prabhu.janakiraman, please refer to sdk docs https://sdk.s-watcher.com/wiki/en/sidebar/ … user_flags
thanks deal
Thanks
J Prabhu
