Topic: Customizing UI of Wialon
Can I customize the UI of Wialon, how much is possible? and on which version??
Gurtam does offer Personalised Design which will give a slightly different look to the interface. All the elements will be in its usual place with different fonts and colours.
You can also limit the number of apps, top menu bar items. (But these can be selected again from the top right menu.
You are of-course free to build your own trimmed down tracking platform using the SDK, as shown in our Wialon playground (https://sdk.s-watcher.com/playground)
As you can see the possibilities are endless as far as customisation goes.
Best regards
