How to get both id and position information in single search api call
(edited by roshan.chhetri 05/07/2017 23:18:12)
Topic: How to get both id and position information in single search api call
I used below api request to get the last known position of all machines:
'http://hst-api.s-watcher.com/wialon/ajax.html?sid=' + session_id + '&svc=core/search_items&params={"spec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1024,"from":0,"to":0}'
But it does not give me the information about the device id.
How can i find it?
I can do search by id but I want to find the information for all machine in a single api call.
I tried batch call also,
search_url = 'http://hst-api.s-watcher.com/wialon/ajax.html?svc=core/batch&params=['all_ids and flag=1024']&sid=' + session_id
but once I provide ids in batch , the response does not have the id hence i cannot differenciate the devices
Re: How to get both id and position information in single search api call
Hello
You can combine flags to get all needed information
From docs
1 - base flag
1024 - last message and position
Send flags=1025 if you need both
roshan.chhetri wrote:
Thanks it worked, the information "t" in the response is the timestamp in seconds?
Yes, we use Unix time
Response format here
Good post, thanks!
thanks
