Installing Ruptela Pro4 + Technoton DUT-E 232 & configuring in Wialon
(edited by jhdeguate 10/06/2017 03:07:39)
Topic: Installing Ruptela Pro4 + Technoton DUT-E 232 & configuring in Wialon
Hello Gurtam community...  We are going to do our first FLS installation in Wialon Hosting using Ruptela Pro4 + Technoton DUT-E-232, and we are requesting help for any distributor that has done that before.  We need help on the best settings for the fuel sensor (as we know how to do the settings on Ruptela units using serial port RS232), and also we need to know the best configuration in Wialon Hosting, for this units we will use.
Thanks a lot for all the help we can get on this...
Best regards from the "land of Volcanoes" (Guatemala)
  • Installing Ruptela Pro4 + Technoton DUT-E 232 & configuring in Wialon
Re: Installing Ruptela Pro4 + Technoton DUT-E 232 & configuring in Wialon
Dear Jary,
Technoton support team has already added you on skype. Please feel free to address them any questions on settings.
thanks a lot AndrewTT...
I also looking for the sensor´s configuration in Wialon... If you know it I will appreciate if you can send it to me...
Regards...
Sensor is easily configured in Wialon
Here is the manual https://docs.s-watcher.com/en/hosting/cms/ … sors/props
PM me if having any particular questions
