Notification on beacon disconnection
(edited by christian.amani 30/05/2017 02:53:57)
Topic: Notification on beacon disconnection
Hi guys,
I would like to know if it is possible to notify a user (by email or sms), when a beacon (Device) is voluntarily disconnected from a vehicle.
I searched in the Wialon Hosting documentation (specifically the Notification pane: http://docs.s-watcher.com/en/hosting/user/notify/trigger), but I was not satisfied.
Re: Notification on beacon disconnection
As "beacons" are used as Trailers or Passengers you just use notification for trailers or passengers...
Wolf.
Thanks for the response.
