Driver Image
Topic: Driver Image
Hi All,
I am trying to get the image from a driver, the API documentation seems to be a little bit vague how to achieve this.
https://sdk.s-watcher.com/wiki/en/sidebar/ … iver_image
First of all, what should be the request ID to be specified in the URL?
http://{host}/avl_driver_image/<rid>/<did>/<max_border>/<any.png>
I tried using Resource ID in place of rid and it returned 404.
http://{host}/avl_driver_image/12345678/3/32
Any help would be appreciated, thanks in advance.
Driver Image
Re: Driver Image
m-ram, just add "/<whatever>.png".
Driver Image
(edited by kaippally 28/05/2017 09:57:40)
Re: Driver Image
The  format is the following
https://dev-api.s-watcher.com/avl_driver_image/<resource_id>/<driver_id>/<size in pixels>/img.png
for example
https://dev-api.s-watcher.com/avl_driver_image/14506958/95/2/img.png
Nishad Hussain Kaippally
Driver Image
Re: Driver Image
m-ram, kaippally, just one note:
you can pass "ck" driver's value instead of "whatever". This method allows browser to show cached icon until it was changed and will prevent showing cached image in case of image changed.
"ck" driver's propery is a counter of icon changes.
Driver Image
Re: Driver Image
