Topic: Geofence Group Enhancement
It would be very useful if there was an option when creating a new Geofence (either from the Geofence heading panel or Address tool "Save as Geofence") to assign it to a Geofence Group as well.
can you explain more ?
Sure!
Currently the only way to work with Geofence Groups is through the 'Geofences' panel and choosing the 'Groups' mode.
http://docs.s-watcher.com/en/hosting/user/geo/groups
Of the three ways (that I know of) when creating a new Geofence, there is no option to add the Geofence to an existing group.
For example:
Method 1: From the 'Geofences' panel (see Diagram 1)
Method 2: From the 'Address' tool (see Diagram 2)
Method 3: From the 'Routing' tool (see Diagram 3)
Adding a new field with a drop-down box to select from existing geofence groups would resolve this.
Hi levon,
thank you for the suggestion. I should note that the feature requested is a minor enhancement. Hence, the priority will be assigned accordingly
New in Wialon beta in July.
You can now add a new geofence to one of the existing groups when creating it in the corresponding tab or “Address” and “Rooting” tools. It will help to start organizing geofences from the start instead of searching for it among the dozens of others thereafter.
