Topic: Display the geofence name instead of address on the messages
Hi Our client is insisting to view the geofence on the message tray instead of address, is it possible?
Not only in the web but also in the Mobile Apps.
A.
A.
as i remember you can use geofences as adress source only in reports (ord riving logbook, notifications etc)
https://docs.s-watcher.com/en/hosting/user/geo/usage
Wolf.
Hello Wolf,
Thanks for the advise but basically what we really need was the real name of geofence on the message tray which is really missing so far.
For the reports, all is well I got all the geofence and was very helpful.
Hope Gurtam team can consider it soon. ![]()
A
Hi Andro,
maybe you explain a little bit more detailed for what you need this? the "raw messages" shown in the logile or in messages is a function, normal endcustomers should not use (execpt you like to get 1000 questions of missunderstanding the raw data.
Wolf.
(not saying that your idea is bad, but i just can not imagine a real usage need for end customers)
