core/use_auth_hash API not Working Recently
Topic: core/use_auth_hash API not Working Recently
Hi,
We have developed one custom app, which uses core/use_auth_hash API for authentication/validation. It returns sessionID which is being used internally for further requests to wialon API.
This API request was working properly but since last few days, its returning error code as -1 which is for "Invalid session"
Request Paramter Format : params : {"authHash":"XXXXX", "operateAs":"YYYY", "checkService":""}
This is happening only on the development environment i.e "dev.hosting.s-watcher.com".
Can you please help me on this.
Thanks
J Prabhu
Re: core/use_auth_hash API not Working Recently
prabhu.janakiraman, when you work with dev.hosting.s-watcher.com - you need to send requests to http://dev-api.s-watcher.com instead of http://hst-api.s-watcher.com.
SID from dev is not compatible with hosting and vice versa. That's why you get 1 code.
Thanks deal, its working now.
Thanks
J Prabhu
