How to get all users/units by creator
Topic: How to get all users/units by creator
Hi,
we would like to get list of all users/units based on creator (i.e the direct users under specific account).
We tried to follow the example under
https://sdk.s-watcher.com/wiki/en/pro/remo … y_property  and the section "Search units by creator".
seems its not working.
Can you please suggest if we are missing anything.
Thanks
J Prabhu
Re: How to get all users/units by creator
Hello, prabhu.janakiraman.
Try this example:
https://hst-api.s-watcher.com/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_unit","propName":"sys_user_creator","propValueMask":"<user_id>","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid=<sid>
