WiaTag Release Notes
Topic: WiaTag Release Notes
New version 1.4 of WiaTag for Android (06.01.2017) & iOS (17.01.2017) is available on Play Market & App Store!
What's new:
- Barcode scanning option. Use WiaTag to read barcode data.
- QR, NFC and linear barcodes preview. Display and check text information on the screen of your smartphone before sending data messages to the server.
- Remote status management. Create templates and change custom status settings via commands.
- General optimization and bug-fixes.
Denis Strakh, Gurtam
Re: WiaTag Release Notes
New version (1.5) of WiaTag is available for android & iOS.
What's new:
- Request configuration - from the monitoring system, you can execute the command "Request configuration" http://joxi.ru/eAORw6JtYVWP2o. Find a configuration file you can to the file server by using the http://apps.s-watcher.com/#disketta application http://joxi.ru/v29XgyEH6JywmG
- Manage custom statuses (available for ios, in the android version will be in the next release) - in the settings of the "Custom statuses", the option "Numeric message`s format" is added. It allows you to additionally register in the message status index: http://joxi.ru/bmo0lbGCKeYl2y
- There was an opportunity to establish phone number for the action "SOS" - if the phone number is set, then when you touch SOS, an automatic call goes to it.
Follow us on Twitter – here you will find up-to-the minute information about new features in the system.
New version (1.6) of WiaTag is available for Android only.
What's new:
- Launch the tracking service from third-party applications;
- Create, add to home screen, and send any number of custom statuses;
- Activate tracking service for specified time periods to increase battery life (via command wiatag_service);
- Fixed issues with displaying UI elements in Arabic;
WiaTag 2.1 Android
• Turning on and off the application service and crash report are added to the Status Messages
• Link preview is added to the chat
• Updated localization for Portuguese (Brazilian)
• Fixed: texts of the offline notifications
Pavel Bushuyeu
Product Owner, Mobile
WiaTag iOS 2.0
• The chat with the dispatcher is added
Pavel Bushuyeu
WiaTag Android 2.2 Update:
- Mass selection of photos is added to the chat
Pavel Bushuyeu
WiaTag 2.3 on iOS and Android
- QR code login to the app is added
For more information see the designated topic.
Pavel Bushuyeu
v2.4 on Android and iOS (on App Store review, will be in the store in a couple of days)
• WiaTag is available on Garmin Fleet 790 in Garmin’s store
• Chat and Remote Control are supported on devices without Google Play Services (such as TomTom Bridge, Garmin Fleet 790, and etc.)
• Improvements in Remote control commands and Chat reliability
• A help screen is added for users that do not have Wialon unit credentials
Pavel Bushuyeu
WiaTag Android 2.4.561:
Admin password is now regulating turning on and off Power Saving mode on the WiaTag’s main screen
With this update you may choose to password-protect enabling and disabling Power Saving mode. Select ‘View Only’ and ‘Select Mode’ in Admin Password - User Mode Access to prompt the password once the user clicks Power Saving Mode on the main screen.
Pavel Bushuyeu
iOS 2.4.3:
Admin password is now regulating turning on and off Power Saving mode on the WiaTag’s main screen is also avaliable on iPhones.
Pavel Bushuyeu
Android: 2.5:
New widgets to manage the application
The use of QR code now is more protected
Parameters "Admin password" and "Remote control" added while creating the QR code
Possibility of reading the QR code from images in the gallery
Bug fixes
iOS 2.5:
Bug fixes
What's New in This Version 2.7
Added possibility to turn on and off chat remotely.
Now you may setup possibility to turn on and off service under the administrator password.
When connected to the platform for the first time, an appropriate parameter will be sent.
Two lines for Custom Statuses on the main screen.
What's New in This Version 2.7.1
Now you may add a comment to coordinates while executing "Send position" command on the platform. This comment will appear with the coordinates in the application.
Yesterday we released a major update for WiaTag on the App Store and Google Play. The update includes:
  • New easy-to-use, intuitive, and modern design
  • New modes optimized for obtaining accurate tracks and moderate battery consumption
  • Cool dark mode
  • BLE-beacon pairing
For more info, please see our blog.
What's New in This Version 3.0.3
Added support for iOS 15
Added the ability to request photos from the device
Improved the command for sending the configuration
Fixed the "Duration" setting in the command used to start/stop the application
Added the "ls" parameter sending
Hi everyone!
A new version of Wialon Android (2.12.22.3368) and iOS (2.12.23) apps were released
What’s new:
We’ve added the ability to display triggered notifications in the unit history. To do this, activate the “Display notifications” switch on the “Unit history” section of the Settings.
Maria Starikova,
