cGuard
(edited by dap 26/12/2016 10:00:14)
Topic: cGuard
Discussion of all questions about the devices
cGuard trackers
All questions about sales - info@cguard.ru or sales@cguard.ru
About technical documentaion, firmware updates and configurator - support@cguard.ru
cGuard
(edited by dap 26/12/2016 10:04:47)
Re: cGuard
latest stable firmware 3.2.0
fits for cGuard Atom, cGuard Litom, and also for cGuard Personal and cGuard Beacon
archive contains two files:
*.bin - for uploading by usb in configurator
*.wln - for remote uploading from Wialon
Re: cGuard
recommendation from my side to the cGuard Beacon which is running since a few months stable without ANY message missing. Allready received more than 2000 messages (1 message = one cicle of wake up from deep sleep, locate gps, send message, go to deep sleep)
Wolf.
cGuard
Re: cGuard
Wolf.
Thank you for your reply, Wolf !
Now I see already 2500 messages )
8 800 250 19 08
www.cguard.ru
cGuard
Re: cGuard
latest cGuard firmware 3.2.1
archive contains 3 files:
changelog - change log for each version
cGuard
Re: cGuard
latest cGuard firmware 3.2.2
cGuard
(edited by dap 27/07/2017 10:28:58)
Re: cGuard
For your consideration, new cGuard firmware for testing -  3.3.0rc9.
Archive contains 2 files:
download fw 3.3.0rc9
Be careful! The firmware is made only for cGuard Atom hw 10.2 and 10.21, cGuard Personal hw 7.2 и 7.25, cGuard Beacon hw 12.1! It doesn't work with Atoms and Personals which were produced earlier tnan February, 2015 (hw 10.0, 7.0)! But it works correctly with cGuard Litoms, though the abilities listed below are not used by cGuard Litoms.
Parameter GPS_MIN_ELEVATION has been added for the devices based on the module Ublox Max-m8, which allows to set the minimal angle of elevation of GPS satellites used for positioning. Besides,  parameter GPS_MV_MODEL, has been added for the devices based on  the module Max-m8, which allows to set up the moving model for the object of monitoring. The default mode is AUTOMOTIVE, but for the objects which move slowly( speed is not higher than 10-12 km/h) mode PEDESTRIAN is preferrable.
There is mode SEA for water transport (if it's not a hydrofoil).
Also there is mode STATIONARY for immobile or almost immobile objects (moving at a speed of 1 km/h or lower).
New parameter ASSET_WAKE_DAY has been added for Personals and Beacons, which allows to set the day of a  week when the device connects to the server. Default value is EVERYDAY.
Parameter ASSET_MV_DETECTOR, has been added for activation of a moving detector in asset mode (if ASSET_MV_DETECTOR equals 1, Personal or Beacon in asset mode starts working as a tracker after actuation of accelerometer).
Parameter ASSET_NAV_TIMEOUT has been added for regulation of fixing positions in asset mode. This parameter starts working after moving detector finishes its work. If moving detector is turned off this parameter starts working after waking of the device.
Message "event 111" is sent at the actuation of moving detector when the objest starts moving.
Be careful! The firmware 3.3.0rc9 is at the stage of testing. Don't risk applying it to the trackers which are out of physical access at the moment, for example if the car is far fom the computer for a long period of time (e.g. a couple of weeks)  so that it can't be connected to cGuard Configurator by USB.
cGuard
Re: cGuard
latest cGuard firmware 3.3.1
archive contains 2 files:
download fw 3.3.1
Be careful! The firmware is made only for cGuard Atom hw 10.2 and 10.21, cGuard Personal hw 7.2 и 7.25, cGuard Beacon hw 12.1 and all cGuard Litoms.
