Incorperating Turn by Turn Directions to units using Google API's
Topic: Incorperating Turn by Turn Directions to units using Google API's
Google API's allow Forward and Reverse Geocoding, and Directions would allow us to pick a location (Mostly the location of a unit) and getting turn by turn instructions to the site. Whether the reason be a Broken Vehicle, a new (unvisited) sites. The feature should be relatively easy as it's not being started from scratch. These applications would be useful to anyone with vehicles out in the field. Buses, Trucks, Cars, It wouldn't matter. Knowing the state of your equipment doesn't matter if it's not easy getting to it.
Thanks guys! Let me know what you think!
Re: Incorperating Turn by Turn Directions to units using Google API's
sorenaveryx, clarify or reformulate your proposition, please. It seems that the topic is some kind of navigation system. And maybe you can describe an example of usage such feature?
Thanks
Tatsiana Shmihelskaya
Business Analyst, Gurtam
