bigger option panel
Topic: bigger option panel
Hello,
http://prntscr.com/dgf3ch
Can you add the option to make bigger/smaller this panel?  also to move it to see back of it?
Thanks
Regards
Locating things
bigger option panel
Re: bigger option panel
locationGPS, you mean the list of criteria?
It is bigger when you are not in the edit mode.
Katerina Alexandrova
Product Manager (Mobile)
bigger option panel
http://prntscr.com/dij06v
Maybe like this is more clear..
thanks
Locating things
bigger option panel
We wouldn't like to make this dialog resizeable  because it has too many fields, rows, check-boxes, inputs, tabs, and other controls. So, they all will move when resized and will create an unpleasant view.
bigger option panel
I see it quite fancy, amazing and pretty view ! better than Gatsby one!
http://prntscr.com/djtc4v
Please see if you agree with me.
thanks
Locating things
bigger option panel
Yes, I see...
bigger option panel
Will you make me happy then?
Locating things
bigger option panel
We don't think that "jumping" inputs and checkboxes could be a good improvement for Wialon.
bigger option panel
mmm. it is not "jumping" it is just doing it web friendly when adjusting the panel to work easier mode. in my opinion of course.
nevermind, leave it
thanks
Locating things
