Generating messages layer with python
(edited by florin1 01/12/2016 09:46:14)
Topic: Generating messages layer with python
Hello guys. I need some help creating messages layer for downloading history period of units. I have this code, works ok getting the units list, but i get this error "WialonError(Invalid input render_create_messages_layer (4))" from the render_create_messages_layer. Any advice? Thanks
from wialon.api import Wialon, WialonError
from wialon import flags
import json
starttime = "1478736000"
endtime = "1479600000"
try:
    wialon_api = Wialon()
    result = wialon_api.token_login(token='token')
    wialon_api.sid = result['eid']
    result = wialon_api.avl_evts()
    print result
    spec = {
        'itemsType': 'avl_unit',
        'propName': 'sys_name',
        'propValueMask': '*',
        'sortType': 'sys_name'
    interval = {"from": 0, "to": 0}
    try:
        units = wialon_api.core_search_items(spec=spec, force=1, flags=flags.ITEM_DATAFLAG_BASE, **interval)
        for i in units['items']:
            gen = {
                'layerName': 'arhivamesaje',
                'itemId': i['id'],
                'timeFrom': starttime,
                'timeTo': endtime,
                'tripDetector': 0,
                'trackColor': 'cc713cff',
                'trackWidth':5,
                'arrows':1,
                'points':1,
                'pointColor':0,
                'annotations':1,
                'flags':0
            print i['nm']
            try:
                meslayer = wialon_api.render_create_messages_layer(spec=gen)
            except WialonError as e:
                print e
        print e
    wialon_api.core_logout()
    pass
Re: Generating messages layer with python
Hello
You passed wrong params to render_create_messages_layer call
// Wrong
// Right
meslayer = wialon_api.render_create_messages_layer(**gen)
Thanks shmi. It Works
Another question.
This python script that i made, runs every night to generate and download the messages archive for all the units of a specific account, from the day before. The problem is that it generates messages from the day before at hour 02:00:32 am to next day at hour 01:59:47 am, not from 00:00:00 day before to 00:00:00 current day.
Any ideea why? Thanks
import json
import urllib
import time
import datetime
import dateutil.relativedelta
import calendar
import os
import re
d = datetime.datetime.now().date()
d2 = d - datetime.timedelta(days=1)
timpstart = calendar.timegm(d2.timetuple())
timpsfarsit = calendar.timegm(d.timetuple())
print "Data Start " + str(d2) + ". Data sfarsit " + str(d)
print "Data start unix " + str(timpstart) + ". Data sfarsit unix " + str(timpsfarsit)
try:
    result = wialon_api.token_login(token='TOKEEEEEENNNN')
    print result
    spec = {
    try:
            layerN = i['nm']
            repl = re.sub('[() ]', '', layerN)
            gen = {
            'layerName': repl,
            'itemId': i['id'],
            'timeFrom': timpstart,
            'timeTo': timpsfarsit,
            'tripDetector': 0,
            'trackWidth': 5,
            'arrows': 1,
            'points': 1,
            'pointColor': 0,
            'annotations': 1,
            'flags': 0
            print i['nm'] + "ID: " + str(i['id'])
            for j in range (0,5):
                try:
                    print ("Generating messages layer...")
                    if meslayer:
                        print ("Downloading unit history...")
                        papi = wialon_api.sid
                        folder = str(d2)
                        if not os.path.exists(folder):
                            os.makedirs(folder)
                            urllib.urlretrieve("https://hst-api.s-watcher.com/wialon/ajax.html?svc=exchange/export_messages&params={'layerName':" + str(repl) +",'format':'wlb','compress':1}&sid=" + papi +"", "" + folder + "/" + repl +".zip")
                        else:
                    print e
                    continue
                break
        print e
    pass
florin1
I think problem in your timezone (looks like UTC+02:00)
You have to send time in UNIX time without any timezone offset
