Custom App Icon - How to add ?
Topic: Custom App Icon - How to add ?
Hi Gurtam,
I am creating a custom App and from the CMS App Configurator page, I am not seeing a way to add my custom icon for my custom App created - can you tell me how to achieve this ?
Thanks in Advance
Karthik
Re: Custom App Icon - How to add ?
karthik, just place icon to /app/logo.png in Your app directory srtucture and make it accessible.
Thanks Deal
Hi Deal
I've followed your instructions but doesn't work for me.
If i'm going to www.myApp.com/app/logo.png i can see it but it doesn't appear on wialon app tab.
Is there a max size for the icon ?
Thanks
janus wrote:
Hi Deal
Thanks
Hello!
This link redirect to other site, not to image file.
In order to add a custom icon to your app added to the apps list in Wialon, please do the following:
Save your logo/icon file named "logo.png" in the application folder named "app" (you need to create a new folder) where your app is hosted. The full server path for the logo should be "/app_URL/app/logo.png". For example, for the app hosted at "http://staging.bluearrowfuel.com", the icon must be located at  "http://staging.bluearrowfuel.com/app/logo.png".
Add your app via "Apps Configurator" in your CMS account (https://docs.s-watcher.com/en/hosting/cms/apps/apps) and in the field "URL:" specify the server path to your app (e.g. http://staging.bluearrowfuel.com)
