Topic: Error 4 on svc=resource/update_notification
I'm trying to create a new notification using Remote API.
https://hst-api.s-watcher.com/wialon/ajax.html?svc=resource/update_notification¶ms={"itemId":13935213,"id":0,"callMode":"create","n":"name1","txt":"dect1","ta":1473019200,"td":0,"ma":0,"mmtd":2,"cdt":2,"mast":2,"mpst":2,"cp":2,"fl":1,"un":[13016217,13016242,14046325],"trg":"speed","act":["push_messages"]}&sid=SIDAbove is the call I'm using. My doubt is whether I'm using the correct itemId param. This value is the value i get under "bact" for call svc=token/login.
