Topic: BCE FM 500 Light cable connection with Relay
Can any One tell me the cable Pin-out connection between BCE FM 500 Light and Ignition Relay and also How to cut of the starter and motion via sms?
Ignition = In5 (Gray/Black wire on BCE connector)
How to cut of the starter and motion via sms? - support@bce.lt or skype: bce_support
I need to know the whole cable connection wiring with car and as well as device, and in5 is for ignition and for relay its out1(purple/black) wire
I want cable connection between car , BCE light and ignition relay, but in this pdf there is no information related to relay
But thanks for the file
GoGPS wrote:I need to know the whole cable connection
Hi Amir,
Are you looking for something in the attached file. If attachment missing send mail to b.abraham@orosgroup.com
