Unable to Access Resources
Topic: Unable to Access Resources
Hello,
I had successfully created a token to login as another user and I was able to access all SDK methods successfully.
But unfortunately on today, I can't access resources (returns null) and execute methods though I can still login successfully with "token/login". please let me know if there may be any change causing this, as I haven't changed anything.
Looking forward !
Re: Unable to Access Resources
I figured out that I am receiving error:1 for every sdk method executed, though I execute every method immediately after login, not waiting the session to expire.
nasnew , there were performed some technical maintenance operations on our data center today (http://noc.s-watcher.com/).
This could case some errors. Are You still experiencing problems now?
Hello, all got back OK, thanks !
