Teltonika FM1010
(10/02/2015 16:41:44 отредактировано Dmitriy)
Тема: Teltonika FM1010
Коллеги, появился прибор Teltonika FM1010, образцы уже отправлены клиентам, а значит можно создавать тему и обсуждать
Teltonika FM1010
TECHNICAL DETAILS:
GSM:
•Quad-band 900/1800 MHz; 850/1900 MHz
•GPRS class 10 (up to 85,6 kbps);
•SMS (text/data)
GPS/GLONASS:
•NMEA protocol compatible. Messages: GGA, GGL, GSA, GSV, RMC, VTG, TXT
•32 channel GPS/GLONASS receiver
•Up to -161 dBm sensitivity
Interface:
•1 Digital Input Reserved for Ignition Status Monitoring (depends on vehicle type)
•Accelerometer
•Power supply (+10...+16) VDC
•Integrated back-up battery (optional)
•Internal High  Gain GSM antenna
•Internal High  Gain GPS/GLONASS antenna
•Dimensions: L(50,7mm)xW(49,6mm)xH(25mm)
•2 Status LEDs
•USB Port
•Configuration and firmware upload (FOTA and via USB cable)
Features:
•Plug and Track
•Small and easy to mount case – directly to car OBDII connector
•Internal GSM antenna and Internal GPS/GLONASS antenna allow mount FM1010 much easier
•Real Time tracking
•Smart algorithm of data acquisition (time, distance, angle, ignition and event based)
•Sending acquired data via GPRS (TCP/IP and UDP/IP protocols)
•Smart algorithm of GPRS connections (GPRS traffic saving)
•Operating in roaming networks (preferred GSM providers list)
•Events on I/O detection and sending via GPRS or SMS.
•Scheduled 24 coordinates SMS sending when GPRS not available
•5 geofence zones (rectangular or circle)
◦Auto  Geofencing  crested  for  car  towing  detection  and  car  theft  prevention
•Deep Sleep mode (less than 2  mA power  consumption)
•FOTA (firmware updating via GPRS)
•3  operational  modes (Home,  Roaming,  Unknown)  based  on  operator
Skype: gamov.euroml
Teltonika FM1010
(18/02/2015 17:26:56 отредактировано ZxR)
Re: Teltonika FM1010
obd2 ?
А считывать что-то умеет?
Внутри ELM ?)))
Teltonika FM1010
(18/02/2015 18:06:09 отредактировано Dmitriy)
ZxR да, OBD. Считывать- нет.
Skype: gamov.euroml
Teltonika FM1010
Хотим интегрировать данный контроллер к нам в систему. Сможет ли кто то поделиться протоколом на данный контроллер?
Teltonika FM1010
postal2 Напишите нам на почту
Skype: gamov.euroml
Teltonika FM1010
Dmitriy пишет:
Написал smile
Teltonika FM1010
Попал на тест этот девайс. Где можно под него скачать конфигуратор и мануал?
Teltonika FM1010
Конфигуратор + программа для апдейта
Опубликовать вложения
Иконка вложений FM1010.zip 1.27 Мб, файл был скачан 1029 раз(а)
Teltonika FM1010
glotechgps пишет:
Спасибо! А мануала с смс-командами случайно не найдется?
Teltonika FM1010
(25/02/2015 19:49:04 отредактировано Rombovik)
Удалось сконфигурировать блок командами из мануала по ФМ1100. Повесил его на порт 5300, на связь вышел но  данных по кану нет... Вообще в этом блоке реализовано считывание с каншины?
Teltonika FM1010
Rombovik пишет:
сам его не видел, но мне очевидно что не может он читать CAN
Teltonika FM1010
(25/02/2015 20:27:32 отредактировано Rombovik)
Sashok пишет:
Rombovik пишет:
Поделитесь, откуда взялась очевидность? Просто если этого функционала нет, тогда он не стоит тех денег, которые за него просят...
Teltonika FM1010
цитирую ТС:
Dmitriy пишет:
в описании прибора на сайте производителя про считывание OBD ни слова.
Если бы он умел что то читать, то производитель похвалился бы и указали сколько тыщ миллиардов моделей автомобилей он понимает. smile
Teltonika FM1010
Sashok пишет:
Не понятно зачем тогда OBD разъем?
Андрей Чудин
Teltonika FM1010
chudin пишет:
нулевая стоимость монтажа. надежность контакта, а отличие от прикуривателя.
это хорошо для таксистов, прокатчиков, женщин и т.д.
Teltonika FM1010
Как привязать на виалон? Какой модель выбирать ?Добавлять как ФМ1100?
Teltonika FM1010
протокол почти у всех одинаковый.
Teltonika FM1010
Добрый день. Можете подсказать Teltonica 1010 в сообщениях приходит параметр Param24, что за параметр?
Teltonika FM1010
Копусов Роман пишет:
Speed
Teltonika FM1010
Мы навали тестировать усовершенственную модель FM1000 с более расширеным протоколом OBD нежели у FM1010. Единственная проблема в том, что тестовый сервер http://wialontest.com/ не поддерживает это устройство в полной мере, по этому пришлось использывать протокол созданный для предыдущей версии.
Реально-ли ожидать, в ближайшее время, добавления нами тестируемого устройства в общую базу данных с полной поддержкой передоваемых данных?
Teltonika FM1010
dds На Wialontest скрипты аналогичны стандартному хостингу, где тоже нет в списке fm1000 (т.к. производитель к нам не обращался с подобной просьбой, и официально никто не предоставлял протокол).
Но, насколько нам известно, все тельтоники работают по одному протоколу. Вы можете выбирать в списке 1010 или любую другую тельтонику.  CAN данные, если они передаются трекером, зашифрованы  в виде параметров param**
Расшифровку номеров параметров Вы можете запросить у производителя, т.к. они могут зависеть от версии прошивки.
Viktor Yarovenko
Teltonika FM1010
Добрый день, не найдется ли у кого расшифровка параметров для fm1010 ?  А то куда не пишу, нигде нет..
Teltonika FM1010
bastit пишет:
1) Куда кинуть?
2) Меняйте дилера Телтоники )
Teltonika FM1010
SAT  Да я брал ради теста, больше там заказывать не буду уж точно)
Если не трудно, то можно на почту bastit@list.ru
Большое Спасибо!)
Teltonika FM1010
bastit
Как вариант включать/выключать по одному параметру и передавать на Wialon. Не самый быстрый способ, но лучше чем ждать
Eduard Vald / GoGPS Service
www.gogps.eu
eduard.vald@gogps.eu
