Topic: JC450 camera how to imput on the wialon plataform?
Good morning!
How do I upload and configure the JC 450 equipment, made by Jimi IoT, on the Wialon platform?
We have already tried the port: 22305 and without success..
Good morning!
Good morning!
Hello,
Please follow the step-by-step guide in the link - https://wialon-help.link/cdebf5e7.
Additionally, we recommend updating the firmware by sending the command:
UPDATE,http://183.238.245.122:1115/download/JC450PRO/update_JC450Pro_FullOta_V1.8.17.zip
The device will download the update over the air (about 300 MB) and update itself. It should take about 20 minutes, and after that you can check that the version was updated by sending the VERSION command.
If you need further assistance, please contact us via support@s-watcher.com.
Best regards,
Maria Valoshyna
Technical Care Engineer (L2 HW)
thanks for the answer! the manual link is not opening...
We have 40 units on hand, but so far we haven't been able to go up... let's try to send the command right now!
the commands were sent like in this print, no more positioning on our platform, as you can see in the second image...
We made several attempts, we got the same command response, please, we need guidance, with video or even an image that gives us a path for this camera to go up on the Wialon platform.. the type is Jimi's 450, we have 40 units to go up to our client, but we are having this major difficulty, please I need more guidance. Thank you for your attention, I await a response that gives me a visual response to this sending of commands to climb onto the platform.
