Measurement system and conversion API
(edited by arsalanqayum332 14/09/2021 12:21:17)
Topic: Measurement system and conversion API
Hi there,
I could not find API for the "units of measurement" such as Mileage (large values), Mileage (small values), Speed, Fuel amount, Fuel consumption, Temperature, Area, Weight, Carrying capacity and Dimensions.
I tried to look into network, but not enough information in there. I wonder if you can direct me to API from here, https://sdk.s-watcher.com/wiki/en/sidebar/ … ref/apiref
By taking a look here, we understand how it works in the hosting side though.
https://help.s-watcher.com/help/wialon-hos … conversion
Best Regards
Sikandar
Re: Measurement system and conversion API
Hello!
Most of such information are calculated in system on back end side. So you can get this data via API by different ways.
For example, you can get Mileage, Speed, Fuel amount, Fuel consumption, Temperature, Weight, Carrying capacity  from report with table Trip
The report template should be created in system, then you can use the following API calls to execute report by certain period -https://sdk.s-watcher.com/wiki/en/sidebar/remoteapi/apiref/report/exec_report
Example https://sdk.s-watcher.com/wiki/en/sidebar/ … es/reports
Hi Diana,
Thank you for your reply. I needed this API for conversion.
https://sdk.s-watcher.com/wiki/en/local/re … sure_units
