Topic: Create notification for custom sensors
I am trying to create a notification for a custom sensor, but I get a message back 'invalid input'. Attached please find my code and an image of the console log.
Best regards
Annanda
Best regards
Annanda
Also, I need to get all the notifications for a resource. Attached please find my code. (I see a similar question was asked August 2018, which is unanswered - subject: "search notification by Name")
I am also using the Javascript API.
Best regards
Annanda
Hello Annanda!
First you need :
load library unitSensors - sess.loadLibrary("unitSensors")
Add flags for unit item- wialon.item.Unit.dataFlag.sensors
( Here you can find all possible libres and flags which needs to upload for using items https://forum.gurtam.com/viewtopic.php? … 3#p161813)
for example,
var flags_res = wialon.item.Item.dataFlag.base
var flags_units = wialon.item.Item.dataFlag.base | wialon.item.Unit.dataFlag.sensors
sess.loadLibrary("unitSensors");
sess.loadLibrary("resourceNotifications");
[{type: "type", data: "avl_resource", flags: flags_res, mode: 0}, // Items (avl_resource) specification
{type: "type", data: "avl_unit", flags: flags_units, mode: 0}], // Items (avl_unit) specification
function (code) { // updateDataFlags callback
if (code) { msg(wialon.core.Errors.getErrorText(code)); return; } // exit if error code
// get loaded 'avl_resource's items with edit notification access
var res = wialon.util.Helper.filterItems(sess.getItems("avl_resource"),
wialon.item.Resource.accessFlag.editNotifications);
for (var i = 0; i< res.length; i++) // construct Select list using found resources
$("#res").append("<option value='"+ res[i].getId() +"'>"+ res[i].getName() +"</option>");
$("#res").change( function(){ getZones(this.value); } ); // bind acion to select change
getZones($("#res").val()); // get geofences for selected resource
var units = sess.getItems("avl_unit"); // get loaded 'avl_unit's items
for (var i = 0; i< units.length; i++) // construct Select list using found units
$("#units").append("<option value='"+ units[i].getId() +"'>"+ units[i].getName() +"</option>");
Regarding notification parameters it seems quite ok, but it's better to specife more correctly,
For example, parameter timezone (tz) you can change to value with DST time, for example timezone UTC+3 with no DST tz = 134228528, is more correct value.
Also you can recheck parameters here in doc , or just create the same notification on monitoring site and look through request in console.
Yes, it's correct way. First you searh (get) resources - getItems("avl_resource"), then for each item(resource) execute getNotifications()
If I am trying to create the notification this way, I get "Invalid input" in the console. What should the value for sensor_type be for a custom sensor?
trg: {// Notification trigger
t: "sensor_value",
p: { sensor_type: "22", sensor_name_mask: "sensorA1", type: "1", lower_bound: "2.5", upper_bound: "4.5" } // trigger parameters ( geozones ids, control type)
"Yes, it's correct way. First you searh (get) resources - getItems("avl_resource"), then for each item(resource) execute getNotifications()"
I've got a couple of notifications set up in Wialon, but using my code to get all the notifications I get "null" back.
t: "sensor_value",
emtpy value for any sensor type - sensor_type: ""
custom sensor - sensor_type: "custom"
You mean the code in file getAllNotifications.js , yes?
Yes, the code in getAllNotifications.js.
The notifications that I've set up in Wialon is also for cutom sensors, and I figured if I can get these notifications I will be able to see exactly what parameter values Wialon uses for custom sensors, but for this code:
var res = sess.getItems("avl_resource");
for (var i = 0; i < res.length; i++) { // construct Select list using found resources
let allNotifications = res(i).getNotifications();
I get "null" back for "allNotifications ".
I still can't create a notification, "Invalid input" in the console. I've changed the sensor_type to "custom" and also tried it with an empty string. I've also tried the sensor_name_mask with an empty string, but to no avail. Below the values in the object. What else could be wrong?
Object
act: Array(1)
0: {t: "message", p: {…}}
length: 1
__proto__: Array(0)
cdt: 10
cp: 3600
fl: 1
la: "en"
ma: 0
mast: 0
mmtd: 3600
mpst: 0
n: "js code new"
sch: {f1: 0, f2: 0, t1: 0, t2: 0, m: 0, …}
ta: 1602242951
td: 1602847751
trg:
p:
lower_bound: "2.5"
type: "1"
upper_bound: "4.5"
__proto__: Object
t: "sensor_value"
__proto__: Object
txt: "Test Notification Text"
tz: 10800
un: 21523455
__proto__: Object
Hello!
There are not correct parameters for notification
Please look after you code the request svc=resource/update_notification is send with the following parameters :
params: {"ma":0,"fl":1,"tz":10800,"la":"en","act":[{"t":"message","p":{}}],"sch":{"f1":0,"f2":0,"t1":0,"t2":0,"m":0,"y":0,"w":0},"txt":"Test Notification Text","mmtd":3600,"cdt":10,"mast":0,"mpst":0,"cp":3600,"n":"js code new","un":19294541,"ta":1602248226,"td":1602853026,"trg":{"t":"sensor_value","p":{"sensor_type":"22","sensor_name_mask":"sensorA1","type":"1","lower_bound":"2.5","upper_bound":"4.5"}},"itemId":930849,"id":0,"callMode":"create"}
The server returns the error error: 4 reason: "VALIDATE_PARAMS_ERROR" = Invalid input , so some parameters are wrong
Please look the example with correct parameters below and try to compare it and use .
{"n":"sensor example","ta":1602201600,"td":0,"tz":134217728,"la":"ru","ma":0,"sch":{"f1":0,"f2":0,"t1":0,"t2":0,"m":0,"y":0,"w":0,"fl":0},"ctrl_sch":{"f1":0,"f2":0,"t1":0,"t2":0,"m":0,"y":0,"w":0,"fl":0},"un":[21728414],"trg":{"t":"sensor_value","p":{"sensor_type":"","sensor_name_mask":"*sensos1*","lower_bound":2.5,"upper_bound":3.5,"prev_msg_diff":0,"merge":1,"type":0}},"d":"","act":[{"t":"message","p":{"name":"sensor example","url":"","color":"","blink":0}}],"txt":"some text.","fl":0,"mast":0,"mpst":0,"cdt":0,"mmtd":3600,"cp":3600,"id":132,"itemId":930849,"callMode":"update"}
Hello Diana
My apologies for bugging you again.
I still can not get the function "getNotifications()" to work. Below new code that I've tried (I've tried less flags):
function getAllNotifications() {
var flags = wialon.item.Resource.dataFlag.base | wialon.item.Resource.dataFlag.notifications;
sess.loadLibrary("resourceNotifications"); // load Notification Library
({ type: "type", data: "avl_resource", flags: flags, mode: 0 }),
if (code) { console.log(window.wialon.core.Errors.getErrorText(code)); return; } // exit if error code
console.log(allNotifications);
Do I perhaps need a parameter for the "getNotifications()" function?
In one of your earlier posts you've mentioned that for the "createNotification()" function I could just create the same notification on the monitoring site and look through request in console. Can you tell me how to this? However, I have now managed to create a notification, (thank you so much for your help), but looking through a request in the console could be a great tool for me to use in future. I just don't know how to look for this in the Wialon code. If you can guide me through this, I would really appreciate it.
The reason why my "createNotification()" function didn't work was because I've used strings(text) for the lower-bound and upper-bound parameter values, while it should have been Integers or Floats, but according to the documentation (here in doc), I thought it should be strings(text)
"lower_bound":<text>, /* sensor value from */
"merge":<text>, /* similar sensors: 0 - calculate separately, 1 - sum up values */
"prev_msg_diff":<text>, /* this flag allows to form boundaries for the current value according to previous value(prev) in such a way:
"sensor_name_mask":<text>, /* sensor name mask */
"sensor_type":<text>, /* sensor type */
"type":<text>, /* trigger: 0 - in specified range, 1 - out of specified range */
"upper_bound":<text>
Thank you in advance!
Annanda
Hi Annanda!
I will check your code more carefully and soon provide you the result.
Please wait.
Hi Diana
Have you found time to look at my code?
Is it possible that maybe the notifications are not set up correctly in Wialon?
Best regards
Annanda
Hi Diana
Best regards
Annanda
Hi Annanda,
please look example here how to create notification sensor control https://sdk.s-watcher.com/playground/dHg2zier/3
The easy way is to look through API parameters in notification when create on monitoring site and just take for obj all parameters except :
id":0,"itemId":93,"callMode":"create"
Regarding getting all notifications there is a problem to get undefined result in your code because when you use call-back function in method sess.updateDataFlags it needs to do something with the result get in callback (all notifications) as method is asynchronous call, for example to show it, to print and etc. Some of way is using more complicated code (to return result) like with Promise / Async/await
Or you just can get result our-side call-back
For example, this function will return mass (massive with resource and its notifications) when executed.
var sess = window.wialon.core.Session.getInstance();
var flags = window.wialon.item.Item.dataFlag.base | window.wialon.item.Resource.dataFlag.base | window.wialon.item.Item.dataFlag.messages | window.wialon.item.Resource.dataFlag.notifications;
var mass = [];
[{ type: "type", data: "avl_resource", flags: flags, mode: 1 }], // Items (avl_resource) specification
var mass = [] //result massive
var obj = {resName: res[i].getName(), allNotif: res[i].getNotifications()}
mass.push(obj);
console.log(mass);
return mass;
Hi Diana
I am afraid still no joy!
Below the result in the console with your example (I've also attached as an image)
Array(2)
0: {resName: "tyrecare", allNotif: null}
1: {resName: "tyretrack1", allNotif: null}
length: 2
__proto__: Array(0)
Could it be that there is something wrong with the notifications I've set up in Wialon? (There are just a few)
For what it's worth, I've also tried your example with a Promise, but to no avail:
async function getAllNotifications() {
let result = await new Promise((resolve, reject) => {
({ type: "type", data: "avl_resource", flags: flags, mode: 1 }),
(code) => {
if (code) {
reject({ type: API_ERROR, error: code });
return;
var mass = () //result massive
var obj = { resName: res(i).getName(), allNotif: res(i).getNotifications() }
mass.push(obj);
resolve(mass);
console.log(result);
Please advise!
Regards
Annanda
Annanda, please look PM message
