Documents Communication protocols
Topic: Documents Communication protocols
Hello friends,
Can someone tell me where to download find the documentation of the communication protocols provided by the platform. I am starting to develop my integration classes implementation with Retranslators and I need the documents and protocol specifications that wialon provides.
- Wialon Retranslator
- Nis
- Granit Navigator
- SCOUT
- Cyber GLX
- Wialon IPS
- VT 300
- EGTS
- SOAP
- TransNavi
- NVG
- RTTI
Cheers,
José Patricio
Saludos,
Sauro Dev
Re: Documents Communication protocols
For retranslator and Wialon IPS there are documents but regarding protocols for the others you need to generate from your incoming server connection as there are no samples.
Phoenix Solusi
Mobile Visible Secure
Jose Donoso  https://gurtam.com/hw/files/Wialon%20Re … 0%20EN.pdf
http://extapi.s-watcher.com/hw/cfg/Wialon%20IPS_en.pdf
The other protocols are not developed by Gurtam and we can't share it. We suggest to use our protocols.
If you want to receive data from Wialon, our retranslators don't wait any ACK that's why you can not to send it. Just parse incoming data.
Viktor Yarovenko
Bonsoir !! j'espère que vous allez bien!!
je cherche comment faire communiquer mon capteur DUT-E GSM avec mon PC à distance pour visualiser les données du capteur sur mon PC en utilisant le protocole wialon IPS
You should set up some TCP server, receive data  and parse the protocol
Or you can become Wialon customer
Viktor Yarovenko
(edited by Jose Donoso 17/07/2020 20:28:12)
Mon ami,
Ici, je laisse le code en C # comme je l'ai fait. Il y a aussi une vidéo qui montre comment cela fonctionne.
https://forum.gurtam.com/viewtopic.php?id=16762
Cordialement
Español
Amigo mio,
Aqui le dejo el codigo en C# como lo hice yo. Tambien hay un video que muestra como funciona.
Saludos
Saludos,
Sauro Dev
