Get Unit ID
Topic: Get Unit ID
I am able to create a unit via API and see it's unit ID in the response. However, is it possible to find the unit ID somwhere in the GUI. I can see the Unique ID in the general properties but I cannot find the unit ID.
Get Unit ID
Re: Get Unit ID
Hello. There exist undocumented feature, that we are using for development, you can open CMS Manager with such url — https://cms.s-watcher.com/?features=avl_id
After that column avl_id will appear and you can click on id to copy it to clipboard:
Get Unit ID
  • Get Unit ID
