Different Map Types on Downloaded Reports
Topic: Different Map Types on Downloaded Reports
At the moment i notice wialon has predefined map type once you download reports on PDF, it does not matter what map type you have selected on the user settings.
It will be great if wialon allows different map types on the report, so that user are free to select on the map they wish to appear on the reports
Thanks
Re: Different Map Types on Downloaded Reports
Dear AmbroseTabalia,
We had such a request before, but it's too hard to implement. This will cause changing the system of saving and using map keys. We may do it in future, but not soon.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Hi,
Some customers will stick to the maps they are familiar with. Not that it is the best map but it is the map they get used to. Hopefully you will implement the feature soon and offer map choices in exported reports.
