Cambio de implementos / Change of Implement
(edited by jose.pacheco 06/05/2019 18:43:43)
Topic: Cambio de implementos / Change of Implement
Existe alguna forma de poder realizar el cambio de implemento desde la aplicación móvil, dada la naturaleza del trabajo esto podría ser una solución que ayude en la fluidez del trabajo.
[English]
There is some way to make the change of implement from the mobile application, given the nature of the work this could be a solution that helps in the flow of work
Re: Cambio de implementos / Change of Implement
jose.pacheco
Please explain your idea in more detail. Do you mean that the driver should be able to assign the correct implement in the mobile application before doing work on a field? Or you mean something else?
Katerina Alexandrova
Product Manager (Mobile)
alek wrote:
jose.pacheco
A good idea would be that the driver should be able to assign the correct trailer (implement) to the mobile application before working in a field
Unfortunately, Wialon mobile application does not have this function.
So, it seems like a separate new application is required for this.
