Not able to execute Any API's Successfully
Topic: Not able to execute Any API's Successfully
I tried executing the following api using postman
https://hst-api.s-watcher.com/wialon/ajax.html?svc=core/login&params={"user":<text>,
               "password":<text>,
               "operateAs":<text>}
This returns 200 status with message error 7.
https://hst-api.s-watcher.com/wialon/ajax.html?svc=core/get_account_data&params={"type":1}
it returns 200 status with message error 1.
Is this the correct methods to call api ? Do we required any extra parms other then what is mentioned in document below.
https://sdk.s-watcher.com/wiki/en/sidebar/ … core/login
We are not able to execute any api. Please suggest or a sample api execution would be very very helpful
Thanks and any help would be highly appriciated
Re: Not able to execute Any API's Successfully
               "password":<text>,
               "operateAs":<text>}
The method you mentioned and tried to login with is old method which no longer available (it's mentioned in this method documentation page).
You should use New authorization way which you can find it in documentation and here is forum discussion about that:
https://forum.gurtam.com/viewtopic.php?id=7875
Thanks, So can we call any other api after we login by the new form mention in the link  https://forum.gurtam.com/viewtopic.php?id=7875
Can you post one example which can be posted into postman and executed.
(edited by satyam87 15/04/2019 20:23:33)
I am getting
    "error": 1
When calling this api
https://hst-api.s-watcher.com/wialon/ajax. … p;params={
        "id":34868,
        "flags":1025
    }&sid=412600aec695f5d02aa26c7d683ea274
can you help me with this, thanks
Please take a look at https://sdk.s-watcher.com/wiki/en/sidebar/ … ors/errors
Your session has expired and you have to login again and get new sid and try to execute commands with new sid.
Just to expand on that too, if I remember correctly sessions last 5 minutes after the last request made with that session id, so you will want to log in and then immediately follow that up with a request using the returned session id while you're testing in postman.
Just exported from postman, Import collection and try to send Search_item request from it
{{SID}} and {{ITEM_ID}} are environment variables, set before testing
Thanks, Most of the api I execute the postman response error 1
Can you please suggest why ?? What may be the issue
Below is the one example of api
Missing sid parameter (Session ID)
Hi
Can you please help me with is api
https://hst-api.s-watcher.com/wialon/ajax. … chart&
    params={
        "attachmentIndex":0,
        "action":0,
        "width":600,
        "height":300,
        "autoScaleY":0,
        "pixelFrom":0,
        "pixelTo":300,
        "flags":513
    }&sid=41364cc1e803095e9e8f6a879e9a119b
This give error 3
https://hst-api.s-watcher.com/wialon/ajax. … eport&
    params={
        "reportResourceId":163266,
        "reportTemplateId":10,
        "reportObjectId":34868,
        "reportObjectSecId":0,
        "interval":{
            "from":1357938000,
            "to":1358715599,
            "flags":0
Thia gives error 7
Hello satyam87 !
1. Before you get chart result you need to execute request exec_report to upload report with chart. After you can execute report/get_result_chart to get chart. Without report executed you will get Error 3
Please look example here how to work with reports
2. there are not such ID = 163266 for element resource, ID = 34868 for unit. Please check ID for required elements. After you login you can get available elements for your user with their ID. Also you can find required elements (resource, unit and etc ) and get their ID by request Search items by property
Hi
I am posting
https://hst-api.wialon.us/wialon/ajax.html?svc=report/get_result_rows&params={"tableIndex":0,"indexFrom":0,"indexTo":10}&sid=41f92e5beaaf27eb88a5220e24f64a46
But it throws
    "error": 5
Error performing request
Can you help me where I am making mistake ??
I have execute request exec_report to upload report but getting
    "error": 7
    params={
        "interval":{
            "from":1357938000,
            "to":1358715599,
            "flags":0
    }&sid=41107f69a4a540132302fc78e37598fc
I did same as given in examle
https://sdk.s-watcher.com/wiki/en/sidebar/ … es/reports
With my sid
When I am calling this api to get bonded driver with unit this throws error
    "error": 4,
    "reason": "VALIDATE_PARAMS_ERROR: {unitId: long}"
https://hst-api.s-watcher.com/wialon/ajax.html?svc=resource/get_unit_drivers&params={"id":400002818}&sid=41b5da9070a5ecb744f1f08be0c73990
Hello!
1. Before you get report result via request report/get_result_rows you need to execute request exec_report to upload report with table data. After you can execute report/get_result_rows to get data from tables. Without report executed you will get Error 5
2. there are not such ID = 163266 for element resource, ID = 34868 for unit. That is why you get error7
    "error": 4,
satyam87
Try replacing the "id" param with "unitId" as described in the docs:
https://sdk.s-watcher.com/wiki/en/sidebar/ … it_drivers
