Mobile app connected to Hecterra
Topic: Mobile app connected to Hecterra
Hi
Just an idea .
If a mobile app just like Logistic app would be connected to Hecterra  then an order can be distributed to mobile device of a driver and maybe more important driver can select Implement or operation from mobile device.
Many more options can be added to mobile app.Driver can see overlaps percentage ,Omissions etc
Best regards
Re: Mobile app connected to Hecterra
aahero
Goos thinking!
However, while we are not developing such a mobile app at the moment, you may create your own app and connect to Hecterra via Hecterra API. That could be real marketing advantage on your side!
Katerina Alexandrova
Product Manager (Mobile)
Totalmente de acuerdo porque esto debe poder registrarse dinamicamente desde un movil
Gracias
