Topic: Active directory or SSO login integration
Is it possible to login with customer SSO or Active directory with his platform
Does the Wialon Local system support this?
Software Operations Manager @ AFAQY LLC
No, unfortunately it's not possible.
Login into Wialon should be done with token which received only (at least one time) via authorization form - https://sdk.s-watcher.com/wiki/en/local/re … ogin/login
Thanks for your support and fast reply.
