Maps update
(15/05/2018 20:25:37 отредактировано crvg19)
Тема: Maps update
I have been working with wialon since last year and all of the features and extras that this platform offers are really great. I just have one problem with it. I’m using the platform to view Guatemala at first, but for a couple of month we have notice that there’s no update map of Guatemala. For example, we have notices a customs port that was built 3 or 4 years ago. And from what we can see there’s no port construction in the maps of Wialon. I have tried to talk to your support and no answer has been received.
I understand that we can’t have the maps update every week, but a couple of years I think it is viable. If someone could help me or give me a contact to talk to I’ll be very grateful.
I’ll attached a pic of the example I’m talking about.
  • Maps update
  • Maps update
Maps update
Re: Maps update
Es por el mapa que utilizas (de seguro es Bing Maps). Te recomiendo utilices los de Google, estoy en El Salvador y los mapas recibieron actualización este año.
Hice la busqueda del área que indicas y puedes ver en el adjunto que están actualizados al 2018.
Para ver que mapas tienes disponible, este es el enlace al manual: https://docs.s-watcher.com/es/hosting/user/gui/map
  • Maps update
Maps update
Re: Maps update
Hello,
Our company provides only technical possibility to add those maps, we gave you the answer that we do not update those maps, it doesǹ`t depend on us. Bing maps contacts can be found in internet.
Also as it`s said above, you can use other maps for satellite view. For further information please contact our support team.
Thanks.
Maps update
Re: Maps update
omendez
Gracias por tu comentario. Una pregunta, yo no tengo los mapas de Google, revise y definitivamente no los tengo. Tu tienes algo o configuraste algo para que pudieras tener los mapas de Google?
Maps update
Re: Maps update
crvg19,
Please, write to support@gurtam.com about Google maps, we'll provide your with necessary information how to add them in Wialon.
