Moving bindings when drivers are moved
Topic: Moving bindings when drivers are moved
We have a number of use cases where we need to move an account to accomodate a change in the structure that we want use and whilst most resoures can be moved will very little effort there is an issue when we want to move a driver. The issue is that the binding history for the driver is lost. The impact is that all reports that use this binding history also will not work correctly.
I would like to recommend an enhancement that allows the binding history to move with the driver to the target account.
Phoenix Solusi
Mobile Visible Secure
Re: Moving bindings when drivers are moved
Dear John,
Thank you for your request! We understand your concern and think carefully about this improvement.
Katerina Alexandrova
Product Manager (Mobile)
JohnG , if you need to move an account, contact our support team. We have a tool that helps to do it. This way we'll keep all drivers messages in safe.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
